With ST to ST termination, this high quality fibre optic patch cable is specifically designed for Fast Ethernet, fibre channel, ATM and Gigabit Ethernet applications. The ST connector features a bayonet locking system. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs.
Product Description | C2G ST-ST 62.5/125 OM1 Duplex Multimode PVC Fiber Optic Cable (LSZH) - patch cable - 30 m - orange | Type | Patch cable - OM1 | Technology | Duplex fibre optic | Type of Fibre Optics | Multimode | Features | Halogen-free | Length | 30 m | Core / Cladding Diameter | 62.5 / 125 micron | Connector | 2 x ST multi-mode - male | Connector (Second End) | 2 x ST multi-mode - male | Colour | Orange | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - OM1 |
Jacket Material | Low Smoke Zero Halogen (LSZH) |
Fibre Qty | 2 |
Length | 30 m |
Colour | Orange |
Connectivity | |
Miscellaneous | |
Compliant Standards | TIA/EIA-455-171A |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 70 °C |
