We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Protect your high speed network from noise and electromagnetic interference when you connect with our shielded Cat5e patch cable. Constructed from high quality cable and plugs, this design minimises Near-End Crosstalk (NEXT) levels. The moulded boot provides extra strain relief and durability. Available in a variety of colours to easily colour-code your network installation.
Product Description | C2G Cat5e Booted Shielded (STP) Network Patch Cable - patch cable - 7 m - blue | Type | Patch cable - CAT 5e | Technology | Shielded twisted pair (STP) | Wiring Scheme | T568B | Shielding Material | Foil | Wires per Cable | 8 wires | Features | Molded | Length | 7 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Blue |
General | |
Network Cable Type | Patch cable - CAT 5e |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Plated Connector | Gold |
Features | Molded |
Length | 7 m |
Colour | Blue |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
