This Cisco SFP-GE-L compatible SFP transceiver provides 1000Base-LX throughput up to 10km over single-mode fibre (SMF) at a wavelength of 1310nm using a LC connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
Product Description | C2G Cisco SFP-GE-L Compatible 1000BASE-LX SMF SFP (Mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - GigE | Device Type | SFP (mini-GBIC) transceiver module - LC single-mode | Form Factor | Plug-in module | Cabling Type | 1000Base-LX | Data Transfer Rate | 1 Gbps | Optical Wave Length | 1310 nm | Data Link Protocol | GigE | Max Transfer Distance | 10 km | OEM Manufacturer Equivalent Part Number | Cisco SFP-GE-L | Dimensions (WxDxH) | 1.27 cm x 5.59 cm x 0.76 cm | Weight | 31 g | Manufacturer Warranty | Limited lifetime warranty | Designed For | Cisco Catalyst 3560X-24P-L, 3560X-24P-S, 3560X-24T-L, 3560X-24T-S, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-L, 3560X-48T-S |
General | |
Device Type | SFP (mini-GBIC) transceiver module |
Colour | Silver |
Networking | |
Connectivity Technology | Wired |
Features | Digital Optical Monitoring (DOM) support |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 1000Base-LX - LC single-mode female x 2 |
Miscellaneous | |
Compliant Standards | MSA |
Dimensions & Weight | |
Width | 1.27 cm |
Depth | 5.59 cm |
Height | 0.76 cm |
Weight | 31 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Compatibility Information | |
