We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The DPE-101GI Power Over Ethernet (PoE) Injector is designed to supply a power and data connection to PoE devices such as an IP Camera or Wireless Access Point.
The DPE-101GI gives you the ability to mount your PoE device virtually anywhere in a building, such as on ceilings or near entryways, by eliminating the need for a nearby power outlet and attached power supply. D-Link’s DPE-101GI combines electrical power with a Gigabit network connection and produces a Gigabit Power over Ethernet (PoE) signal, allowing a single Ethernet cable to carry both data and power to a device.
Cost Efficient Flexibility
Deploying the DPE-101GI saves both installation costs and equipment costs, allowing a single RJ-45 Ethernet cable to carry both power and data to each device. This reduces cables, eliminates the need for dedicated electrical outlets on the wall, ceiling, or other unreachable place, and most of all, reduces installation time.
The Power over Ethernet solution frees IP surveillance cameras and wireless AP deployments from the restrictions of power outlet locations.
High Speed Connectivity
The DPE-101GI Power Over Ethernet (PoE) Injector is designed to be deployed in situations where high bandwidth is demanded. Examples where the DPE-101GI is ideal include powering network devices such as wall mounted PTZ (Pan, Tilt & Zoom) network cameras, ceiling mounted PTZ dome network cameras, video and voice over IP (VoIP) telephones, and multichannel (11a/b/g/n) wireless LAN access points.
Product Description | D-Link DPE-101GI PoE Gigabit injector - PoE injector | Device Type | PoE injector - external | Output connectors | 1 x RJ-45 | Included Accessories | Power adapter | Manufacturer Warranty | 2-year warranty | Designed For | D-Link DAP-2660; AirPremier N PoE Access Point with Plenum-rated Chassis DAP-2360 |
General | |
Power Device | |
Power Output Connectors Details | 1 x RJ-45 |
Expansion / Connectivity | |
Interfaces | 1 x Gigabit LAN - RJ-45 |
Miscellaneous | |
Cables Included | Power cable - external |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
Designed For | D-Link DAP-2660 , D-Link AirPremier N PoE Access Point with Plenum-rated Chassis DAP-2360 |
