Easily adjust your monitor to your desired angle, height, and position so you can enjoy great visuals across multiple monitors with no hassle.
Product Description | Dell P2018H - LED monitor - 20" | Device Type | LED-backlit LCD monitor - 20" | Energy Class | Class D | Energy Consumption per Year | 24 kWh | Power Consumption (On mode) | 9.7 W | Features | USB 3.0 hub | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | 1600 x 900 at 60 Hz | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (black-to-white) | Colour Support | 16.7 million colours | Colour Gamut | 72% (CIE 1931), 84% (CIE 1976) | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 46.15 cm x 18 cm x 33.88 cm | Environmental Standards | ENERGY STAR Qualified EPEAT Gold | Carbon Footprint | 428 kg carbon emissions | Compliant Standards | CECP, CEL, TUV Rheinland Low Blue Light Certification, BFR-free, PVC-free | Manufacturer Warranty | 3-year warranty | Bundled Services | 3-Years Advanced Exchange Service and Premium Panel Guarantee | Designed For | Latitude 7400 2-in-1 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 20" |
Viewable Size | 19.5" |
Built-in Devices | USB 3.0 hub |
Panel Type | TN |
Pixel Per Inch | 94 |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
Features | PowerNap, stand lock, Flicker Free technology, BFR/PVC-free, Energy Gauge, Dell ComfortView |
Dimensions (WxDxH) | 46.15 cm x 18 cm x 33.88 cm - with stand |
Connectivity | |
Interfaces | DisplayPort , HDMI , VGA , 2 x USB 2.0 downstream , USB 3.0 upstream , 2 x USB 3.0 downstream |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x SuperSpeed USB cable , 1 x VGA cable , 1 x DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 9.7 kWh/1000h |
Power Consumption (Typical) | 14 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 46.15 cm - depth: 18 cm - height: 33.88 cm , Without stand - width: 46.15 cm - depth: 5.01 cm - height: 27.32 cm - weight: 2.4 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 6.13 kg |
Sustainability Information | |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR Certified | Yes |
Total CF/unit Standard Deviation (kg CO2e) | 85 |
Manufacturing (kg CO2e) | 301 |
Logistics (kg CO2e) | 36 |
Use (kg CO2e) | 89 |
EOL (kg CO2e) | 2 |
Total Carbon w/o Use Phase (kg CO2e) | 339 |
PAIA Version | 9/5/2018 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Compatibility Information | |
Designed For | Dell Latitude 7400 2-in-1 |
