We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Deliver Full HD presentations to bring sharp images and bright colours to any meeting room with our super-bright business projector. The EB-2255U is designed to project a scalable image up to a massive 300 inches, and offers a range of connectivity options including screen mirroring and Wireless LAN connectivity.
Product Description | Epson EB-2255U - LCD projector - 802.11b/g/n wireless / LAN / Miracast / Intel Wireless Display (WiDi) - white | Device Type | LCD projector - 1080p | Colour | White | Brightness (White) | 5000 lumens | Brightness (Colour) | 5000 lumens | Contrast Ratio | 400:1 / 15000:1 (dynamic) | Resolution | WUXGA (1920 x 1200) | Native Aspect Ratio | 16:10 | Colour Support | 1.07 billion colours | Bulb type | 300 Watt | Bulb life cycle | Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode | Video Input | IEEE 802.11b/g/n wireless / LAN / Miracast / Intel Wireless Display (WiDi) | Speakers | Speaker(s) - integrated | Power | AC 230V (50 - 60 Hz) | Power Consumption Operational | 420 Watt | Dimensions (WxDxH) | 37.7 cm x 29.1 cm x 11 cm | Weight | 4.9 kg | Manufacturer Warranty | 3-year warranty |
General | |
Networking | 802.11b/g/n, Ethernet |
Enclosure Colour | White |
Projector | |
Brightness (Reduced) | 3800 lumens |
Image Size | 127 cm - 762 cm |
Projection Distance | 1.5 m - 9 m |
Throw Ratio | 1.38 - 2.28:1 |
Digital Zoom Factor | 1.6x |
Resolution | WUXGA - WUXGA (1920 x 1200) |
Features | sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, instant on/off |
Lens | |
Focus Type | Manual |
Lens Aperture | F/1.5-2.0 |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -30 / +30 |
Horizontal Keystone Correction | -30 / +30 |
Video Input | |
LAN and Wireless Image Transferring Protocols | IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n, WiDi, Miracast |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 16 Watt |
Expansion / Connectivity | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort - 20 pin DisplayPort , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDBaseT - RJ-45 |
Miscellaneous | |
Included Accessories | Wireless remote control, wireless LAN unit |
Cables Included | 1 x VGA cable |
Security Features | Security lock slot (cable lock sold separately), password protection |
Power | |
Power Source | AC |
Voltage Required | AC 230V (50 - 60 Hz) |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Software Included | EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection |
Dimensions & Weight | |
Width | 37.7 cm |
Depth | 29.1 cm |
Height | 11 cm |
Weight | 4.9 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
Sound Emission | 39 dBA |
Sound Emission (Economic Mode) | 29 dBA |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
