We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
With a brightness of 3,500 lumens and XGA resolution, the EB-680's ultra-short-throw design allows you to present large images from a very short distance with minimised shadows and glare. A 14,000:1 contrast ratio and HDMI input mean that students benefit from sharp, clear images.
Product Description | Epson EB-680 - 3LCD projector - LAN - grey, white | Device Type | 3LCD projector | Colour | Grey, white | Built-in Devices | Speaker | Brightness (White) | 3500 lumens | Brightness (Colour) | 3500 lumens | Contrast Ratio | 300:1 / 14000:1 (dynamic) | Resolution | XGA (1024 x 768) | Native Aspect Ratio | 4:3 | Colour Support | 1.07 billion colours | Bulb type | 250 Watt | Bulb life cycle | Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode | Video Input | RGB, composite video LAN | Speakers | Speaker(s) - integrated | Power | AC 230V (50 - 60 Hz) | Power Consumption Operational | 354 Watt | Dimensions (WxDxH) | 36.7 cm x 40 cm x 14.9 cm | Weight | 5.7 kg | Manufacturer Warranty | 3-year warranty |
General | |
Networking | Ethernet |
Enclosure Colour | Grey, white |
Projector | |
Brightness (Reduced) | 2800 lumens |
Image Size | 142 cm - 236 cm |
Projection Distance | 0.4 m - 0.6 m |
Throw Ratio | 0.32:1 |
Digital Zoom Factor | 1.35x |
Resolution | XGA - XGA (1024 x 768) |
Features | sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode |
Lens | |
Focus Type | Manual |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -3 / +3 |
Horizontal Keystone Correction | -3 / +3 |
Video Input | |
Analogue video Signal | RGB, composite video |
Video Interfaces | VGA, HDMI, composite video, MHL |
LAN and Wireless Image Transferring Protocols | Wired LAN |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 16 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI , 2 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) |
Miscellaneous | |
Included Accessories | Wireless remote control |
Cables Included | 1 x USB cable |
Mounting Kit | Included |
Security Features | Security lock slot (cable lock sold separately), password protection |
Power | |
Power Source | AC |
Voltage Required | AC 230V (50 - 60 Hz) |
Power Consumption Stand by | 0.39 Watt |
Software / System Requirements | |
Software Included | EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection |
Dimensions & Weight | |
Width | 36.7 cm |
Depth | 40 cm |
Height | 14.9 cm |
Weight | 5.7 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years / 8000 hours - carry-in , Limited warranty - lamp - 1 year / 1000 hours |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Sound Emission | 35 dBA |
Sound Emission (Economic Mode) | 28 dBA |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
