ITEM | QTY | PRICE |
HP 301 2-pack Black/Tri-color Origina...
4 | £152.32 |
C2G 10m Cat6 550 MHz Snagless Patch C...
3 | £43.32 |
DrayTek Vigor 2832n ADSL Router w/Wir...
3 | £677.40 |
We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Superior image quality
Ensure superb quality and the best possible delivery of presentations with this powerful installation projector for large venues. Featuring Epson's own 3LCD technology and equally high White and Colour Light Output, WUXGA resolution images are vivid and bright, even in daylight with its 7,000 lumens brightness. For a next-level viewing experience, the projector features 4K enhancement, giving images exceptional sharpness, clarity and detail.
Easy positioning
Thanks to a new range of motorised lenses, including optional ultra-short throw (UST) lens, and both vertical and horizontal lens shift, the projector benefits from true 360° installation flexibility allowing it to be placed almost anywhere.
Quick set-up
Get started quickly thanks to a lens memory function, which stores projector settings such as image position, focus and zoom, for prompt access when projecting images in different aspect ratios, or using different lenses. Split-screen allows dual feeds to be projected, while a portrait projection mode is possible without changing the lamp. For integration with a wide range of systems, inputs include HDMI, HDBaseT, DVI-D and component video.
Product Description | Epson EB-G7900U - 3LCD projector - LAN | Device Type | 3LCD projector - 1080p | Built-in Devices | Speaker | Brightness (White) | 7000 lumens | Brightness (Colour) | 7000 lumens | Contrast Ratio | 2000:1 / 50000:1 (dynamic) | Resolution | WUXGA (1920 x 1200) | Native Aspect Ratio | 16:10 | Colour Support | 1.07 billion colours | Lens Shift Direction | Horizontal, vertical | Bulb type | 400 Watt | Bulb life cycle | Up to 2000 hours - normal mode , Up to 4000 hours - economic mode | Video Input | RGB, component video LAN | Speakers | Speaker(s) - integrated | Power | AC 120/230 V (50/60 Hz) | Power Consumption Operational | 572 Watt | Dimensions (WxDxH) | 52.5 cm x 47.2 cm x 18.9 cm | Weight | 12.7 kg |
General | |
Networking | Ethernet |
Projector | |
Brightness (Reduced) | 5600 lumens |
Image Size | 127 cm - 762 cm |
Projection Distance | 1.5 m - 15.1 m |
Throw Ratio | 1.44 - 2.33:1 |
Resolution | WUXGA - WUXGA (1920 x 1200) |
Features | sRGB colour profile, EPSON 3LCD technology, DICOM Simulation Mode, Dynamic Mode |
Lens | |
Focus Type | Powered |
Lens Aperture | F/1.7-2.3 |
Zoom Type | Powered |
Zoom Factor | 1.6x |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -45 / +45 |
Horizontal Keystone Correction | -30 / +30 |
Lens Shift Type | Powered |
Vertical Lens Shift | 67% / 67% |
Horizontal Lens Shift | 30% / 30% |
Video Input | |
Analogue video Signal | RGB, component video |
Video Interfaces | VGA, HDMI, component video, DVI |
LAN and Wireless Image Transferring Protocols | Wired LAN |
Speakers | |
Type | Integrated |
Expansion / Connectivity | |
Interfaces | 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x HDBaseT , 1 x component video input - BNC x 5 , 1 x audio line-out - mini-phone stereo 3.5 mm , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) |
Miscellaneous | |
Included Accessories | Cable cover, remote control |
Cables Included | 1 x VGA cable |
Security Features | Security lock slot (cable lock sold separately) |
Power | |
Power Source | AC |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Width | 52.5 cm |
Depth | 47.2 cm |
Height | 18.9 cm |
Weight | 12.7 kg |
Environmental Parameters | |
Humidity Range Operating | 20 - 80% |
Sound Emission | 39 dB |
Sound Emission (Economic Mode) | 31 dB |
