We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Maximize your workspace with the Mini-in-One display that fully encloses a USFF PC and is purpose-built to seamlessly connect, contain, secure, and power your Mini - from this generation to the next. Multi-task like a pro in Full HD resolution, and add your USB devices at the display.
Product Description | HP Mini-in-One 24 - LED monitor - Full HD (1080p) - 23.8" - Smart Buy | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class E | Power Consumption (On mode) | 17.8 W | Features | USB 3.1 Gen 1 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 800000:1 (dynamic) | Response Time | 14 ms (grey-to-grey), 5 ms (overdrive) | Colour Gamut | 72% NTSC | Input Connectors | DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black, silver (stand) | Dimensions (WxDxH) - with stand | 53.96 cm x 24.2 cm x 50.38 cm | Weight | 7.2 kg | Localisation | English / United Kingdom | Manufacturer Selling Program | HP Smart Buy | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen, ICE |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Built-in Devices | USB 3.1 Gen 1 hub |
Panel Type | IPS |
Pixel Per Inch | 93.24 |
Vertical Refresh Rate | 50 - 60 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 6500K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, 3-sided micro-edge, 72% NTSC colour gamut |
Dimensions (WxDxH) | 53.96 cm x 24.2 cm x 50.38 cm - with stand |
Weight | 7.2 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | DisplayPort (HDCP) , USB 3.1 Gen 1 upstream (Type B) , 6 x USB 3.1 Gen 1 downstream (Type A) , USB-C 3.1 Gen 1 (HDCP) , Audio line-in , Audio line-out |
Mechanical | |
Tilt Angle | -5/+30 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 17.8 kWh/1000h |
Power Consumption (Typical) | 50 Watt |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 53.96 cm - depth: 24.2 cm - height: 50.38 cm - weight: 7.2 kg , Without stand - width: 53.96 cm - depth: 7.5 cm - height: 36.76 cm - weight: 4.06 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 65 cm |
Shipping Depth | 47.3 cm |
Shipping Height | 31.5 cm |
Shipping Weight | 12.78 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
