The G-MASTER Red Eagle gives true gamers the competitive edge they need to make split second decisions. It spikes down on your enemies with a blistering response time, ensuring fluid and accurate transition between the images.
Product Description | iiyama G-MASTER Red Eagle GB2788HS-B2 - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class B | Energy Consumption per Year | 49 kWh | Power Consumption (On mode) | 34 W | Adaptive-Sync Technology | AMD FreeSync | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 144 Hz | Pixel Pitch | 0.311 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 12000000:1 (dynamic) | Response Time | 1 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, DisplayPort | Display Position Adjustments | Height, swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 64.35 cm x 23 cm x 41.2 cm | Weight | 6.9 kg | Compliant Standards | DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | TN |
Vertical Refresh Rate | 55 - 145 Hz |
Horizontal Refresh Rate | 30 - 160 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Japanese |
Features | HDCP, Eco-Mode, Overdrive technology, game mode, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, blue light reduction, Black Tuner |
Colour | Black |
Weight | 6.9 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2.5 Watt |
Connectivity | |
Interfaces | DisplayPort , DVI-D , HDMI , Headphones , Audio line-in |
Mechanical | |
Tilt Angle | 17 |
Swivel Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x DisplayPort cable - DisplayPort to DisplayPort |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 35 Watt |
