With its Full HD (1920x1080) resolution and accurate Projective Capacitive 10 point touch technology, the ProLite T2252MSC-B1 delivers seamless and accurate touch response. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angels, making it a perfect choice for a vast array of interactive applications. The flexible stand can be positioned at several angels creating a comfortable and ergonomic user experience. In addition, the edge-to-edge glass and ultra slim design creates an eye-catching finish. The ProLite T2252MSC-B1 is the ideal solution for interactive signage, instore retail, POS and interactive presentations.
Product Description | iiyama ProLite T2252MSC-B1 - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" - touchscreen | Energy Class | Class F | Energy Consumption per Year | 38 kWh | Power Consumption (On mode) | 17.8 W | Features | Touch-screen | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | 7H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 49.05 cm x 22.05 cm x 37.05 cm | Weight | 2.16 kg | Compliant Standards | DDC-2B, VESA DPMS, cULus, TUV Bauart, CU | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | IPS |
Vertical Refresh Rate | 55 - 76 Hz |
Horizontal Refresh Rate | 24 - 83 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese |
Features | HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), X-Res Technology, scratch-resistant, Projected Capacitive Touch (P-CAP) technology |
Colour | Black |
Weight | 2.16 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Input | |
Type | Touch-screen - touchscreen |
Connectivity | |
Interfaces | VGA , DisplayPort , HDMI (HDCP) , Headphones , USB |
Mechanical | |
Tilt Angle | -3/+73 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Stand |
Cables Included | 1 x VGA cable , 1 x HDMI cable , 1 x audio cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 17.8 kWh/1000h |
Power Consumption (Typical) | 18.1 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows Vista / 7 / 8 / 8.1 / 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
