Providing excellent picture performance, the ProLite XU2595WSU is a great choice for office applications, graphics applications and CAD applications. The monitor features an IPS Technology LED panel offering 1920 x 1200 native resolution with accurate color reproduction and wide viewing angles. The blue light reducer function and flicker-free LED's helps to significantly limit eye fatigue typically caused by working with a computer screen.
Product Description | iiyama ProLite XU2595WSU-B1 - LED monitor - 25" | Device Type | LED-backlit LCD monitor - 25" | Energy Class | Class F | Power Consumption (On mode) | 20.5 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB 2.0 hub | Panel Type | IPS | Aspect Ratio | 16:10 | Native Resolution | WUXGA 1920 x 1200 at 75 Hz | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 16.7 million colours (8-bit) | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Matte | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 54.65 cm x 18 cm x 43.85 cm | Weight | 3.9 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | CB, RoHS, WEEE, TUV Bauart, EAC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 25" |
Built-in Devices | USB 2.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 89 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Polish, Russian, Japanese |
Features | Ultra Slim Design, HDCP, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, i-Style Color, Blue Light Filter technology |
Colour | Black |
Weight | 3.9 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , HDMI (HDCP) , DisplayPort , 2 x USB 2.0 , Headphone input |
Mechanical | |
Tilt Angle | -5/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 20.5 kWh/1000h |
Power Consumption (Typical) | 28 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
