Expand Hue to your outdoors. The Turaco wall can be connected to your existing Hue bridge to get all the features like away from home control, geofencing and scheduling.
Product Description | Philips Hue White Turaco - wall lamp - LED light bulb - E27 - 9 W - anthracite | Product Type | Wall lamp | Light Source Type | LED light bulb | Supported Light Bulbs Qty | 1 | Dimmer | Yes | Colour | Anthracite | Socket Type | E27 | Wattage | 9 W | Light Bulb Energy Efficiency Class | A+ | Intelligent Assistant | Google Assistant, Alexa - indirect | Platform | Apple HomeKit, Hue | Voltage Required | AC 220 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Compatible Light Bulb Energy Class | A, B, C, D, E, A++, A+ |
Dimmer | Yes |
Waterproof | Yes |
Features | Double insulated, weatherproof, outdoor usage, splashproof, remote controlled, adjustable lighting time, auto power on/off, day/night adjustable sensor |
Light Source | |
Socket Type | E27 |
Wattage | 9 W |
Lifetime | 20000 hours |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Intelligent Assistant | Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Product Material | Aluminium, synthetics |
Body Colour | Anthracite |
Compliant Standards | IP44 |
Warranty | 2 years |
Dimensions & Weight | |
Width | 101 mm |
Depth | 118 mm |
Height | 212 mm |
Weight | 889 g |
Shipping Dimensions (WxDxH) / Weight | 118 mm x 132 mm x 265 mm / 1.233 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
