We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Get warm-to-cool white light with the ST72 bulb. Featuring an E27 base, coiled inner filament, instant dimming and the full suite of smart light features, this LED bulb brings old and new together.
Product Description | Philips Hue White ambiance - LED filament light bulb - shape: ST72 - clear finish - E27 - 7 W - warm to cool white light - 2200-4500 K | Light Source Type | LED filament light bulb | Shape | ST72 | Bulb Finish | Clear | Socket Type | E27 | Wattage | 7 W | Wattage Equivalent | 40 W | Energy Efficiency Class | G | Colour of Illumination | Warm to cool white light | Colour Temperature | 2200-4500 K | Luminous Power | 550 lumens | Beam Angle | 360 degree(s) | Dimmable | Yes | Intelligent Assistant | Siri, Cortana, Google Assistant, Alexa - indirect | Platform | Apple HomeKit, Hue | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 220 - 240 V | Frequency Required | 50/60 Hz |
Light Source | |
Shape | ST72 |
Socket Type | E27 |
Wattage | 7 W |
Energy Consumption per 1000h | 7 kWh |
Power Factor | 0.6 |
Colour Rendering Index | 80 |
Dimmable | Yes |
Lifetime | 15000 hours |
Switch Cycles | 50000 |
Features | Upgradable firmware, instant full light, Android compatible, iOS compatible, voice control, remote controlled, app-controlled, coiled filament |
Power Requirements | |
Power Consumption Stand by | 0.5 Watt |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Intelligent Assistant | Siri, Cortana, Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Package | Hanging box |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 72 mm |
Length | 164 mm |
Weight | 56 g |
Shipping Dimensions (WxDxH) / Weight | 14.6 cm x 10 cm x 20.9 cm / 178 g |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
