Philips hue combines brilliant LED light with intuitive technology. It will surely change the way you use light. Forever. Experiment with shades of white, from invigorating blue/white to cozy yellow/white. Or play with all the colors in the spectrum. Hue can wake you up. Help protect your home. Relive your favorite memories. Improve your mood. Even keep you informed about the weather. Not just stunning, hue is smart too. And it's tailored for you.
Product Description | Philips Hue White and Color Ambiance - LED light bulb - shape: B39 - E14 - 6.5 W - 16 million colours - 2200-6500 K | Light Source Type | LED light bulb | Shape | B39 | Socket Type | E14 | Wattage | 6.5 W | Energy Efficiency Class | A+ | Colour of Illumination | 16 million colours | Colour Temperature | 2200-6500 K | Dimmable | Yes | Intelligent Assistant | Indirect | Platform | Hue | Communications Technology | Zigbee | Voltage Required | AC 220 - 240 V |
Light Source | |
Shape | B39 |
Socket Type | E14 |
Wattage | 6.5 W |
Energy Consumption per 1000h | 6.5 kWh |
Dimmable | Yes |
Lifetime | 25000 hours |
Features | Upgradable firmware, instant full light |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Platform | Hue |
Communications Type | Product-to-product |
Voice Controlled | Indirect |
Miscellaneous | |
Package | Hanging box |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 39 mm |
Length | 117 mm |
