Product Description | Philips Hue White and colour - LED light bulb - shape: A19 - E27 - 10 W - 16 million colours - 2000-6500 K | Light Source Type | LED light bulb | Shape | A19 | Socket Type | E27 | Wattage | 10 W | Wattage Equivalent | 60 W | Energy Efficiency Class | A+ | Colour of Illumination | 16 million colours | Colour Temperature | 2000-6500 K | Luminous Power | 800 lumens | Lighting Details | - 342 lumens , - 570 lumens , - 800 lumens , - 550 lumens | Beam Angle | 160 degree(s) | Dimmable | Yes | Voltage Required | AC 220 - 240 V |
Light Source | |
Shape | A19 |
Socket Type | E27 |
Wattage | 10 W |
Colour Rendering Index | 80 |
Luminous Efficacy | 80 lm/W |
Dimmable | Yes |
Lifetime | 25000 hours |
Features | Upgradable firmware, instant full light, remote controlled |
Power Requirements | |
Miscellaneous | |
Warranty | 2 years |
Dimensions & Weight | |
Height | 110 mm |
Diameter | 62 mm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
