E27 White Bulbs
£24.99
Twin Pack
Bring smart light anywhere in your home with two E27 smart LED bulbs offering soft white light. Suitable for most light fixtures, these bulbs offer instant wireless dimming.
Product Description | Philips Hue White - LED light bulb - shape: A60 - E27 - 9 W - warm white light - 2700 K - white (pack of 2) | Light Source Type | LED light bulb | Packaged Quantity | 2 (specifications are for single item) | Colour | White | Shape | A60 | Socket Type | E27 | Wattage | 9 W | Wattage Equivalent | 60 W | Energy Efficiency Class | F | Colour of Illumination | Warm white light | Colour Temperature | 2700 K | Luminous Power | 806 lumens | Dimmable | Yes | Intelligent Assistant | Siri, Cortana, Google Assistant, Alexa - indirect | Platform | Hue | Communications Technology | Bluetooth | Voltage Required | AC 220 - 240 V |
General | |
Light Source | |
Shape | A60 |
Socket Type | E27 |
Wattage | 9 W |
Energy Consumption per 1000h | 9 kWh |
Colour Rendering Index | 80 |
Dimmable | Yes |
Lifetime | 25000 hours |
Switch Cycles | 50000 |
Features | Upgradable firmware, instant full light, app-controlled |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Platform | Hue |
Communications Type | Product-to-product |
Intelligent Assistant | Siri, Cortana, Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Body Colour | White |
Package | Box |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 61 mm |
Length | 110 mm |
Weight | 72 g |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
