Discover the ground-breaking 49-inch super ultra-wide curved monitor from Samsung, with 32:9 aspect ratio. Giving you a more comfortable viewing experience and more realistic colours with Quantum dot and HDR technology. The CHG90 49" monitor make working in the office easy with powerful multi-tasking with picture-by-picture and easy setting software.
Display more of your documents
With its 32:9 aspect ratio the 49" super ultra-wide curved panel provides all the space you need to display more of your data-rich documents. The CHG90 offers a view so panoramic that you can keep many windows open at once and work comfortably with less scrolling and zooming.
No more dual-monitor inconvenience
Equivalent to two 27" monitors side by side, the super ultra-wide panel eliminates the need for traditional dual monitor setups with mismatched screens, awkward bezel breaks and multiple cables cluttering your office space. With the CHG90 QLED monitor, you can do it all on a single monitor.
More lifelike color
HDR and Samsung’s advanced QLED technology are capable of producing more realistic color than conventional monitor technologies. Which means that whatever the task in front of you, you can be sure the colors you see onscreen are truer to those around you.
Maximum multitasking efficiency
The Picture-by-Picture function simultaneously displays input from different devices without losing any of the original image quality. You can simply hook up your Galaxy S8/S8+with the Samsung DEX Station to manage all your mobile content alongside other onscreen projects.
Work smarter with Easy setting box Soft Ware
With its intuitive interface and options designed for maximum efficiency, Easy Setting Box Soft Ware lets you quickly and easily partition the screen or display multiple screens of various sizes in a variety of configurations. Multitask smarter with Easy setting box.
PIP + DeX Station
Letting you resize a second image up to 25% of the screen and position it anywhere you want, Picture-in-Picture makes multitasking simple whatever you are working on. And connect the DeX Station to keep any eye on all your mobile calls, messages and more.
Ideal for long hours of work
Engineered to match the natural curvature of your eyes, the ergonomic 1800R curved panel offers enhanced viewing comfort compared to traditional flat screens. And Samsung’s Flicker Free technology and blue light-reducing Eye Saver Mode minimize eye fatigue when working for extended periods.
Enhanced speed and fine control
The superfast response time, 144hz screen refresh rate, and AMD freeSync maximize productivity when working with photo and video files, ensure smoother display and playback, and provide fine cursor control for accuracy. With the CHG90, you can handle even the most demanding tasks with ease.
Increase your ergonomic efficiency
It swivels, tilts, and is height-adjustable, compatible with VESA-standard monitor arms. With these functions at your disposal, you can effortlessly position your screen at whatever height and angle you want and share the onscreen content with nearby coworkers.
Multiple input ports that connect to any device
Featuring DP, Mini-DP and multiple HDMI and USB ports, the CHG90 lets you connect almost any device you can imagine with minimum fuss. So, whatever device you, your colleagues, or your clients choose to use, you can always rely on the CHG90.
Product Description | Samsung C49HG90DMU - CHG9 Series - QLED monitor - curved - 49" - HDR | Device Type | QLED monitor - 49" | Energy Class | Class G | Energy Consumption per Year | 104 kWh | Power Consumption (On mode) | 71 W | Curved Screen | Yes | Features | USB 3.0 hub | Panel Type | VA | Aspect Ratio | 32:9 | Native Resolution | 3840 x 1080 at 144 Hz | Brightness | 600 cd/m² | Response Time | 1 ms | Colour Support | 1.07 billion colours | Colour Gamut | 92% Adobe RGB | Input Connectors | 2xHDMI, DisplayPort, Mini DisplayPort | Display Position Adjustments | Height, swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black coal | Dimensions (WxDxH) - with stand | 120.3 cm x 38.16 cm x 52.55 cm | Weight | 15 kg |
General | |
Display Type | QLED monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 49" |
Viewable Size | 48.9" |
Curved Screen | Yes (1800R) |
Built-in Devices | USB 3.0 hub |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | HighBrightness, picture by picture, Cinema Mode, Mega Dynamic Contrast Ratio, CustomColor Mode, On-screen Digital Controls, FPS Mode, RTS Mode, Factory Calibration, Eye Saver Mode, DAS Mode (Dynamic Action Sync), Quantum Dot Technology, 1ms Motion Blur Reduction, RPG Mode |
Dimensions (WxDxH) | 120.3 cm x 38.16 cm x 52.55 cm - with stand |
Weight | 15 kg |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , Mini DisplayPort , Headphones , 2 x USB 3.0 , USB 3.0 upstream , Audio line-in |
Mechanical | |
Tilt Angle | -2/+15 |
Swivel Angle | 30 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x DisplayPort cable , 1 x HDMI cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 71 kWh/1000h |
Power Consumption HDR (On mode) | 78 kWh/1000h |
Power Consumption (Typical) | 71 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
Included Software | Easy Setting Box |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 120.3 cm - depth: 38.16 cm - height: 52.55 cm - weight: 15 kg , Without stand - width: 120.3 cm - depth: 19.44 cm - height: 36.94 cm |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
