The UE850 UHD monitors offer rich picture contrast and rapid response time, creating a more life-like, non-distracting visual experience that simultaneously enhances performance. The UE850's improved resolution and dynamic connectivity drive efficiency for professional, creative and analytical tasks. Combined with ergonomic and environmentally-friendly advancements, the UE850 monitors deliver a complete, comfortable viewing experience. True-to-life picture quality and image reproduction accuracy are critical to the display experience, improving functionality and productivity, and creating an immersive in-home entertainment experience. By addressing the various needs of consumers and professionals, the UE850 monitors continue the rapid transition of display technology and digital signage to UHD standard.
Product Description | Samsung U28E850R - UE850 Series - LED monitor - 28" | Device Type | LED-backlit LCD monitor - 28" | Energy Class | Class G | Energy Consumption per Year | 56 kWh | Power Consumption (On mode) | 39 W | Features | USB 3.0 hub | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | 4K UHD (2160p) 3840 x 2160 at 60 Hz | Pixel Pitch | 0.16 mm | Brightness | 370 cd/m² | Contrast Ratio | 1000:1 | Response Time | 1 ms (black-to-white) | Colour Support | 1 billion colours | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V | Colour | Black, titan silver | Dimensions (WxDxH) - with stand | 66.11 cm x 26.06 cm x 42.15 cm | Weight | 7.43 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | TUV GS |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 28" |
Built-in Devices | USB 3.0 hub |
Panel Type | TN |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | MagicBright, picture by picture, MagicRotation, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, BFR/PVC-free, Image Size, PIP 2.0, USB Super-charging, Eye Saver Mode |
Dimensions (WxDxH) | 66.11 cm x 26.06 cm x 42.15 cm - with stand |
Weight | 7.43 kg |
Connectivity | |
Interfaces | Headphones , 2 x HDMI , DisplayPort , 4 x USB 3.0 |
Mechanical | |
Tilt Angle | -5/+22 |
Swivel Angle | 50 |
Rotation Angle | -1.5/+91.5 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption SDR (On mode) | 39 kWh/1000h |
Power Consumption Stand by | 0.3 Watt |
Software / System Requirements | |
OS Required | Apple MacOS, Windows 8.1 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 66.11 cm - depth: 26.06 cm - height: 42.15 cm - weight: 7.43 kg , Without stand - width: 66.11 cm - depth: 6.07 cm - height: 38.45 cm - weight: 4.94 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
