Add reliable and cost-effective 10 Gigabit Ethernet connections over multimode fiber, with this SFP+ module. This 10GBase-LRM SFP+ module delivers what you need most in your network connections: reliable performance. It's built to exacting MSA specifications and fully tested to ensure seamless compatibility. The multimode SFP+ transceiver module offers a cost-effective way to add, replace or upgrade the ports on your networking equipment.
With data transfer rates of up to 10Gbps and support for Digital Diagnostics Monitoring (DDM / DOM), this LC SFP+ module can be installed into fiber networking equipment with an MSA compliant port. It delivers dependable 10 Gigabit connectivity over multimode fiber for 10GBase-LRM compliant networks, with a maximum distance of up to 220 m/721.7 ft. and 1310 nm optical wavelength.
This optical transceiver is engineered to meet or exceed the industry's MSA (Multi-Source Agreement) standards. StarTech.com brings its established reputation for high-quality connectivity solutions to SFP transceivers, providing SFPs that match major OEM brands in performance and reliability. Committed to the highest standards, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile solution that's compatible with a wide range of networking equipment, allowing you to expand your network to remote segments cost-effectively.
Product Description | StarTech.com MSA Uncoded Compatible SFP+ Module, 10GBASE-LRM, 10GbE Multi Mode (MMF) Fiber Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 200m, 1310nm, DDM, Mini GBIC Module - Lifetime Warranty (SFP10GBLRMST) - SFP+ transceiver module - 10GbE | Device Type | SFP+ transceiver module - LC multi-mode | Form Factor | Plug-in module | Cabling Type | 10GBase-LRM | Data Transfer Rate | 10 Gbps | Optical Wave Length | 1310 nm | Data Link Protocol | 10GbE | Max Transfer Distance | 220 m | Dimensions (WxDxH) | 1.39 cm x 5.84 cm x 1.26 cm | Weight | 30 g | Manufacturer Warranty | Limited lifetime warranty |
General | |
Device Type | SFP+ transceiver module |
Colour | Silver |
Networking | |
Connectivity Technology | Wired |
Features | Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM) |
Compliant Standards | IEEE 802.3ae |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 10GBase-LRM - LC multi-mode female x 2 |
Miscellaneous | |
Compliant Standards | FCC, RoHS, WEEE, MSA, RCM |
Dimensions & Weight | |
Width | 1.39 cm |
Depth | 5.84 cm |
Height | 1.26 cm |
Weight | 30 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 5 - 95% |
