Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The 45PATCH15BL Cat5e Patch Cable (15 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
Product Description | StarTech.com Cat5e Ethernet Cable15 ft - Blue - Patch Cable - Snagless Cat5e Cable - Network Cable - Ethernet Cord - Cat 5e Cable - 15ft - patch cable - 4.6 m - blue | Type | Patch cable - CAT 5e | Technology | Unshielded twisted pair (UTP) | Wires per Cable | 8 wires | Features | Snagless | Length | 4.6 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Blue | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: DKT30CHVCM, DKT30CHVGPD, DKT30CHVPD2, NETRS2322P, PM1115P2, PM1115U2, PM1115UW, PM1115UWEU, ROLLOVER, US1GC301AU, US1GC301AU2R, US1GC301AUW, US1GC30B, US1GC30W, USB31000S2 |
General | |
Network Cable Type | Patch cable - CAT 5e |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Length | 4.6 m |
Colour | Blue |
Connectivity | |
Miscellaneous | |
Compliant Standards | UL |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
