Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT2BL Cat5e Patch Cable (2 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
Product Description | StarTech.com Cat5e Ethernet Cable - 2 ft - Blue - Patch Cable - Molded Cat5e Cable - Short Network Cable - Ethernet Cord - Cat 5e Cable - 2ft (M45PATCH2BL) - patch cable - 0.6 m - blue | Type | Patch cable - CAT 5e | Technology | Unshielded twisted pair (UTP) | Wiring Scheme | T568A | Wires per Cable | 8 wires | Features | Molded | Length | 0.6 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Blue | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: MCM110SC2P |
General | |
Network Cable Type | Patch cable - CAT 5e |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Features | Molded |
Length | 0.6 m |
Colour | Blue |
Connectivity | |
Miscellaneous | |
Compliant Standards | UL |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
