StarTech.com 3 ft mDP to HDMI cable - 4K
Key features
  • Achieve astonishing picture quality with support for 4K resolution at 30 Hz
  • Reduce the clutter caused by adapters, with a cable that connects directly from your computer to your display
  • Avoid the hassle of power adapters, with a plug-and-play cable adapter that does not require external power
Product codes
chevron icon
chevron icon
Eliminate clutter by connecting your Mac or PC directly to an HDMI display using this short cable. This 3-foot Mini DisplayPort to HDMI adapter cable offers a single-cable connection from your mDP equipped MacBook or Ultrabook laptop to an HDMI display or projector. The passive adapter supports video resolutions up to Ultra HD 4K and is Thunderbolt compatible when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
This adapter cable ensures you can maintain an astonishing picture quality, four times the resolution of 1080p, when converting Mini DisplayPort to HDMI.
The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
For the simplest and most discreet installation, this mDP to HDMI adapter connects directly from your Mini DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate video cabling.
At 3ft in length, this adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For longer installations, StarTech.com also offers a 6 ft mDP to HDMI cable (MDP2HDMM2MW) enabling you to choose the right cable length for your custom installation needs.
The MDP2HDMM1MWis a stylish white adapter that looks great next to your Mac computer.
chevron icon
Product Description StarTech.com Mini DisplayPort to HDMI Converter Cable - 3 ft (1m) - mDP to HDMI Adapter with Built-in Cable - (M / M) Ultra HD 4K - White (MDP2HDMM1MW) - adapter cable - DisplayPort / HDMI - 1 m
Cable Adapter cable - DisplayPort / HDMI
Length 1 m
Colour White
Connector Mini DisplayPort - male
Connector (Second End) HDMI - male
Compliant Standards DisplayPort 1.2
Features 4K support
chevron icon
Accessories
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
