StarTech.com 6ft mDP to HDMI cable - 4K
Key features
  • PRODUCT PERFORMANCE: 6.6ft (2m) Mini DisplayPort 1.2 to HDMI 1.4 cable connects your mDP host to a HDMI display/monitor | Supports Ultra HD (UHD) 4K 30Hz (3840x2160) or 4096x2160 @ 24Hz video, 7.1ch Audio, HDCP 1.4, DPCP | Backward compatible with 1080p
  • HOST COMPATIBILITY: Passive Mini DisplayPort to HDMI cable supports mDP++ source including Thunderbolt 1 & 2 MacBooks, MacBook Air & Mac Mini, Microsoft Surface Pro 1-6, desktops (AMD FirePro/NVidia Quadro), laptops, mini itx computers, Intel NUC & docks
  • INTEGRATED DISPLAY CABLE: Mini DP to HDMI adapter cable has flexible design w/ adapter chip built into HDMI connector reducing clutter & providing a tidy install in the office, boardroom or home office; 6.6' (2m) cable length for easy routing/install
  • RELIABLE CONNECTION: mDP to HDMI cable provides a direct connection to your HDMI monitor, display or projector; The chip is built into the HDMI connector which minimizes signal loss, providing a crystal clear image
  • EASY TO USE: With no software or drivers required, the Mini DP to HDMI converter cable/cord works with any OS including macOS, Windows & Ubuntu; Compatible with MiniDP devices like Microsoft Surface PCs or TB1/TB2 MacBooks
Product codes
chevron icon
chevron icon
Eliminate clutter by connecting your PC or Mac directly to an HDMI display. This 6-foot Mini DisplayPort to HDMI adapter cable offers a single-cable connection from your mDP equipped MacBook or Ultrabook laptop to an HDMI display or projector. The passive adapter supports video resolutions up to Ultra HD 4K and is Thunderbolt compatible when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
This adapter cable ensures you can maintain an astonishing picture quality, four times the resolution of 1080p, when converting Mini DisplayPort to HDMI.
The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
For the simplest and most discreet installation, this mDP to HDMI adapter connects directly from your Mini DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate video cabling.
At 6ft in length, this adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For shorter installations, StarTech.com also offers a 3 ft mDP to HDMI cable (MDP2HDMM1MB) enabling you to choose the right cable length for your custom installation needs.
chevron icon
Product Description StarTech.com 6ft Mini DisplayPort to HDMI Cable - 4K 30hz Monitor Adapter Cable - mDP PC or Macbook to HDMI Display (MDP2HDMM2MB) - adapter cable - DisplayPort / HDMI - 2 m
Cable Adapter cable - DisplayPort / HDMI
Length 2 m
Colour Black
Connector Mini DisplayPort - male
Connector (Second End) HDMI - male
Compliant Standards DisplayPort 1.2
Features 4K support
chevron icon
Accessories
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
