StarTech.com 8in SATA to Right Angle SATA Serial ATA Cable
£4.77
Delivery:
Notify me
  • Length: 20.3cm
  • Type: SATA
Product codes
chevron icon
Make a right-angled connection to your SATA drive, for installation in tight spaces. The SATA8RA1 Right Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a right-angled SATA receptacle, providing a simple 8-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The right-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
As an alternative, StarTech.com also offers an 8in Left Angle SATA cable (SATA8LA1), which provides the same simple installation as this right angled SATA cable, but allows the cable to connect to the SATA drive from the opposite direction.
chevron icon
Product Description StarTech.com 8in SATA to Right Angle SATA Serial ATA Cable - 8in SATA Cable - 8 SATA Cable - right angle SATA Cable - SATA cable - 20.3 cm
Type SATA cable
Interface Speed Serial ATA 150/300/600
Technology Shielded
Features Right-angled connector
Length 20.3 cm
Connector 7 pin Serial ATA - receptacle
Connector (Second End) 7 pin Serial ATA - receptacle
Colour Red
Designed For P/N: USB2SATAIDE, USB3SSATAIDE
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£4.77
Notify me
