Connect your MacBook, Chromebook or laptop with USB-C to a DVI monitor or projector. This USB-C to DVI adapter lets you output DVI video from a USB Type-C device such as a MacBook, Chromebook or Dell XPS laptop. The adapter works with USB-C devices that pass a DisplayPort video signal and it's also compatible with Thunderbolt 3 ports.
This USB Type-C video adapter is highly portable, with a small footprint and a lightweight design. It's the perfect accessory for your MacBook or Chromebook, fitting easily into your laptop bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
The adapter supports dual-link video resolutions up to 2560x1600. You'll be surprised at the picture quality the adapter provides, even when connected to a DVI monitor, projector or television. The adapter harnesses the video capabilities that are built into your USB Type-C connection, to deliver every detail in stunning resolution.
This adapter lets you enjoy the versatility of your portable device's USB Type-C port. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work.
The CDP2DVIW features a white housing that looks great with your MacBook.
Your USB-C equipped device must support video to work with this adapter. Some legacy DVI monitors may be limited to a resolution of 1920x1200 when used with this adapter.
Product Description | StarTech.com USB C to DVI Adapter - White - 1920x1200 - USB Type C Video Converter for Your DVI D Display / Monitor / Projector (CDP2DVIW) - external video adapter - white | Device Type | External video adapter | Bus Type | USB-C | Max Resolution | 2560 x 1600 | Interfaces Details | DVI-I | Enclosure Colour | White | Manufacturer Warranty | 3-year warranty | Designed For | P/N: TB4CDOCK |
General | |
Bus Type | USB-C |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Compatibility Information | |
