We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
3M Framed Desktop Monitor Privacy Filters offer outstanding privacy protection; allowing only those directly in front of the monitor to see on-screen data. Anti-reflective surface reduces screen glare. Fits 16" to 17" CRT monitors and 17" widescreen LCD desktop monitors. Actual filter viewing area dimensions are 14 15/16" wide x 9 1/2" high (379mm x 242mm). Two easy-to-use attachment methods - 3M Command adhesive and attachable hanger arms. Helps protect the display from scratches and fingerprints. Easy to clean surface is smudge-resistant and repels permanent marker.
Product Description | 3M Lightweight LCD Privacy Filter PF317W - display privacy filter - 17" wide | Product Type | Display privacy filter | Colour | Black | Display Screen Size Compatibility | 17" wide | Dimensions (WxDxH) | 41.4 cm x 1 cm x 26.3 cm | Manufacturer Warranty | 1 year warranty |
General | |
Dimensions (WxDxH) | 41.4 cm - 1 cm - 26.3 cm |
Colour | Black |
Miscellaneous | |
Features | Anti-glare, anti-reflective |
Manufacturer Warranty | |
Service & Support | 1 year warranty |
Service & Support Details | Limited warranty - 1 year |
