Convenient stacking columns raise the monitor from 7/8" to 5 7/8" in increments of 1 5/8" to help ensure the proper viewing angle. Easily accommodate most laptops and office supplies with 16" clearance underneath the platform. It features no-skid base and is great for laptops, printers or monitors up to 17" or 40 lbs.
Product Description | 3M Adjustable Monitor Stand Extra Wide MS90B - stand - for monitor / notebook / printer - black, silver | Product Type | Stand - desktop | Dimensions (WxDxH) | 45.7 cm | Adjustable Height | 2.54-14.9 cm | Adjustments | Height | Recommended Use | Monitor / notebook / printer | Recommended Display Size | 17" | Max Load Weight | 18.1 kg | Colour | Black, silver |
General | |
Width | 45.7 cm |
AV Furniture | |
Type | Stand |
Placing / Mounting | Desktop |
Features | Adjustable height |
