Ideal for use in office environments, libraries and computer labs, Professional Series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
Product Description | Acer B226HQL - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class F | Energy Consumption per Year | 27 kWh | Power Consumption (On mode) | 19 W | Features | Stereo speakers | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 250 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 8 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI, VGA | Speakers | Integrated | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V | Colour | Dark grey | Dimensions (WxDxH) | 50.8 cm x 20.43 cm x 36.82 cm | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Built-in Devices | Stereo speakers |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | ErgoStand, Acer EcoDisplay, ComfyView |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 1 Watt |
Connectivity | |
Interfaces | VGA , DVI , HDMI |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 60 |
Rotation Angle | 90 |
Height Adjustment | 150 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x DVI cable |
Security Slot Type | Kensington security slot |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V |
Power Consumption SDR (On mode) | 19 kWh/1000h |
Power Consumption (Typical) | 19.5 Watt |
Power Consumption Sleep | 0.35 Watt |
On / Off Switch | Yes |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 50.8 cm - depth: 20.43 cm - height: 36.82 cm , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm |
Sustainability Information | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
