Acer B226HQLymdr 21.5" 1920x1080 VGA DVI Monitor
Key features
  • 22" widescreen LCD display
  • 1920 x 1080 resolution
  • 100,000,000:1 contrast ratio
  • 8ms response time
  • Integrated speakers
  • DVI with HDCP
  • VGA
  • Adjustable display angle
Product codes
Ideal for use in office environments, libraries and computer labs, Professional Series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
Product Description Acer B226HQL - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5"
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 100000000:1 (dynamic)
Response Time 5 ms (On/Off)
Colour Support 16.7 million colours
Input Connectors DVI, VGA
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Dark grey
Dimensions (WxDxH) 50.8 cm x 22.1 cm x 36.9 cm
Weight 5.81 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer B226HQLymdr 21.5"...
