The ultra-lightweight Acer C series LED pico projector fits easily in your pocket. Carry it along with an external device and you can present anywhere, even without a PC. Sufficient battery life beams your videos, photos and on-the-spot business presentations in various formats.
Product Description | Acer C120 - DLP projector | Device Type | DLP projector | Brightness | 100 lumens | Contrast Ratio | 1000:1 | Resolution | WVGA (854 x 480) | Native Aspect Ratio | 16:9 | Colour Support | 16.7 million colours | Bulb type | LED | Bulb life cycle | Up to 20000 hour(s) | Power | AC 120/230 V | Power Consumption Operational | 20 Watt | Dimensions (WxDxH) | 12 cm x 8.2 cm x 2.6 cm | Weight | 180 g |
General | |
Projector | |
Brightness (Reduced) | 75 lumens |
Image Size | 25 cm - 254 cm |
Projection Distance | 0.4 m - 3.7 m |
Throw Ratio | 1.65:1 |
Resolution | WVGA - WVGA (854 x 480) |
Max Sync Rate (V x H) | 60 Hz x 32.2 kHz |
Bulb type | LED |
Features | USB powered, SmartFormat Technology |
Lens | |
Focus Type | Manual |
Lens Aperture | F/1.87 |
Expansion / Connectivity | |
Interfaces | 1 x USB 3.0 |
Miscellaneous | |
Included Accessories | Carrying case |
Cables Included | 1 x USB cable |
Power | |
Voltage Required | AC 120/230 V |
Power Consumption Operational (Standby) | 0.5 Watt |
Dimensions & Weight | |
Width | 12 cm |
Depth | 8.2 cm |
Height | 2.6 cm |
Weight | 180 g |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 90% (non-condensing) |
Sound Emission | 30 dBA |
Sound Emission (Economic Mode) | 24 dBA |
