We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Upgrade your display
Get everyone to sit up and take notice with a display that can reach up to 300 inches. From delivering presentations to streaming box sets at home, experience a display that's up to three times brighter than competitor products, thanks to 3LCD technology . In addition to its bright and vivid colours, the 15,000:1 contrast ratio produces defined shadows and deep blacks.
Myth-busting brightness
Bright rooms are no match for this projector – with 4,400 lumens, this powerful yet affordable model delivers exceptionally bright yet colourful images with clear details. It utilises Epson's renowned 3LCD technology, which produces an equally high White and Colour Light Output.
Long-lasting solution
Durable and affordable, this model's long-lasting lamp light source means you'll be able to project your content every day for six years .
Set up has never been so easy
Keep your cool setting up this hassle-free projector. Keystone correction lets you position the image, while the array of inputs and outputs ensure that it's easy to access content. It includes two HDMI inputs (including one MHL), two VGA in, VGA out, and it's also network enabled via RJ45. Thanks to the optional ELPAP10 adapter, it also offers Wi-Fi connectivity, allowing you to share content from a smart device using the iProjection app.
Product Description | Epson EB-2042 - 3LCD projector - LAN - white | Device Type | 3LCD projector | Colour | White | Built-in Devices | Speaker | Brightness (White) | 4400 lumens | Brightness (Colour) | 4400 lumens | Contrast Ratio | 15000:1 (dynamic) | Resolution | XGA (1024 x 768) | Native Aspect Ratio | 4:3 | Colour Support | 1.07 billion colours | Bulb type | UHE 230 Watt | Bulb life cycle | Up to 5500 hour(s) - normal mode , Up to 12000 hour(s) - economic mode | Video Input | RGB, composite video LAN | Speakers | Speaker(s) - integrated | Power | AC 120/230 V (50 - 60 Hz) | Power Consumption Operational | 331 Watt | Dimensions (WxDxH) | 30.9 cm x 29.3 cm x 105 cm | Weight | 3 kg | Manufacturer Warranty | 2-year warranty |
General | |
Networking | Ethernet |
Enclosure Colour | White |
Projector | |
Brightness (Reduced) | 2490 lumens |
Image Size | 76 cm - 762 cm |
Throw Ratio | 1.38 - 2.24:1 |
Resolution | XGA - XGA (1024 x 768) |
Max Sync Rate (V x H) | 120 Hz |
Features | Blackboard Mode, EPSON 3LCD technology, Dynamic Mode, Presentation Mode |
Lens | |
Focus Type | Manual |
Lens Aperture | F/1.51-1.99 |
Zoom Type | Manual |
Zoom Factor | 1.6x |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -30 / +30 |
Horizontal Keystone Correction | -30 / +30 |
Video Input | |
Analogue video Signal | RGB, composite video |
Video Interfaces | VGA, HDMI, composite video, MHL |
LAN and Wireless Image Transferring Protocols | Wired LAN |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 16 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x microphone |
Miscellaneous | |
Included Accessories | Wireless remote control, HDMI cable clamp |
Cables Included | 1 x VGA cable |
Security Features | Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock |
Power | |
Power Source | AC |
Voltage Required | AC 120/230 V (50 - 60 Hz) |
Power Consumption Stand by | 0.2 Watt |
Dimensions & Weight | |
Width | 30.9 cm |
Depth | 29.3 cm |
Height | 105 cm |
Weight | 3 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Sound Emission | 37 dBA |
Sound Emission (Economic Mode) | 28 dBA |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
