Marketing description is not available.
Product Description | Acer CB351C - LED monitor - 35" | Device Type | LED-backlit LCD monitor - 35" | Energy Class | Class B | Energy Consumption per Year | 72 kWh | Power Consumption (On mode) | 49 W | Features | USB 3.0 hub | Panel Type | VA | Aspect Ratio | 21:9 | Native Resolution | 2560 x 1080 at 60 Hz | Brightness | 300 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI, DisplayPort | Display Position Adjustments | Height, swivel, tilt | Voltage | AC 120/230 V | Colour | Black | Environmental Standards | ENERGY STAR Qualified |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 35" |
Built-in Devices | USB 3.0 hub |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | ErgoStand, Acer EcoDisplay, ComfyView, Flicker-Less technology, sRGB Colour Correction technology, Blue Light Filter technology, Super Sharpness technology, EyeProtect |
Colour | Black |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | DisplayPort , HDMI , DVI-D (dual link) , 2 x USB 3.0 downstream , USB 3.0 upstream , Audio line-in , Audio line-out |
Mechanical | |
Tilt Angle | -5/+25 |
Swivel Angle | 120 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x DisplayPort cable , 1 x DVI cable , 1 x SuperSpeed USB cable |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
On / Off Switch | No |
Sustainability Information | |
ENERGY STAR Certified | Yes |
