Marketing description is not available.
Product Description | Acer XR342CK - LED monitor - curved - 34" | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class B | Energy Consumption per Year | 78 kWh | Power Consumption (On mode) | 53 W | Curved Screen | Yes | Daisy Chaining | Yes | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 21:9 | Native Resolution | 3440 x 1440 | Brightness | 300 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 1 ms (MPRT) | Colour Support | 1.07 billion colours | Colour Gamut | 100% sRGB | Input Connectors | HDMI, HDMI (MHL), DisplayPort, Mini DisplayPort | Display Position Adjustments | Height, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 81.62 cm x 30.9 cm x 56.55 cm | Weight | 9.7 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 34" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Backlight Technology | LED backlight |
Features | 6-axis colour adjustment, DTS Sound, Adaptive-Sync technology, adjustable ambient lighting |
Colour | Black |
Dimensions (WxDxH) | 81.62 cm x 30.9 cm x 56.55 cm - with stand |
Weight | 9.7 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 7 Watt |
Connectivity | |
Interfaces | HDMI , MHL / HDMI , DisplayPort , DisplayPort output , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out , USB-C |
Mechanical | |
Tilt Angle | -5/+35 |
Height Adjustment | 130 mm |
Miscellaneous | |
Features | Flicker-free technology |
Cables Included | 1 x DisplayPort cable , 1 x SuperSpeed USB cable , 1 x HDMI cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption Stand by | 500 mW |
Power Consumption Sleep | 480 mW |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 81.62 cm - depth: 30.9 cm - height: 56.55 cm - weight: 9.7 kg , Without stand - width: 81.62 cm - depth: 12.47 cm - height: 36.77 cm - weight: 6.55 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
