Marketing description is not available.
Product Description | Acer ED242QRAbidpx - LED monitor - curved - Full HD (1080p) - 23.6" | Device Type | LED-backlit LCD monitor - 23.6" | Energy Class | Class F | Power Consumption (On mode) | 27 W | Curved Screen | Yes | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 144 Hz | Pixel Pitch | 0.27156 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 100000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 84% NTSC | Input Connectors | HDMI, DVI, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Colour | Black | Localisation | United Kingdom | Compliant Standards | MPR II | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.6" |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Acer Adaptive Contrast Management (ACM), ComfyView, Flicker-Less technology, Blue Light Filter technology, 8-bit gamma, Wide Viewing Angle, Acer BluelightShield technology, Ultra-Low Blue Light Technology |
Colour | Black |
Connectivity | |
Interfaces | DisplayPort , DVI , HDMI , Audio line-out (mini-jack) |
Mechanical | |
Tilt Angle | -5/+20 |
Miscellaneous | |
Cables Included | 1 x DisplayPort cable - DisplayPort to DisplayPort |
Power | |
Power Consumption SDR (On mode) | 23 kWh/1000h |
Power Consumption (Typical) | 36 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
