The Acer G series displays engaging high-definition visuals and crystal-clear text on its cinematic widescreen. The brilliant design and simplified functionality make the great value of this monitor easy to see!
Product Description | Acer G227HQL - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class A | Energy Consumption per Year | 29 kWh | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Brightness | 250 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Colour | Black | Dimensions (WxDxH) - with stand | 49.9 cm 38.4 cm | Weight | 2.8 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | MPR II | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Panel Type | IPS |
Backlight Technology | LED backlight |
Features | Acer Adaptive Contrast Management (ACM) |
Colour | Black |
Dimensions (WxDxH) | 49.9 cm 38.4 cm - with stand |
Weight | 2.8 kg |
Connectivity | |
Interfaces | VGA , DVI , HDMI |
Mechanical | |
Tilt Angle | -5/+15 |
Miscellaneous | |
Included Accessories | Stand |
Cables Included | 1 x VGA cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Power Supply | External |
Power Consumption (Typical) | 24 Watt |
Power Consumption Stand by | 490 mW |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 49.9 cm - height: 30.3 cm - weight: 2.5 kg , With stand - width: 49.9 cm - height: 38.4 cm - weight: 2.8 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
