The eco-friendly Acer K2 series monitors are an affordable display solution for everyday PC use. They offer a hassle-free experience without compromising image quality. The intelligent design brings together a multitude of connections, superb performance, and eco-friendliness, all at a price point that'll make you smile.
Product Description | Acer K242HQLC - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class F | Energy Consumption per Year | 39 kWh | Power Consumption (On mode) | 27 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.2715 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | Response Time | 1 ms | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | HDMI, DVI, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 56.7 cm x 20.79 cm x 42.12 cm | Weight | 4.24 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | MPR II | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.6" |
Panel Type | TN |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | HDCP, Acer EcoDisplay, High Frame Rate Control (Hi-FRC), 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 56.7 cm x 20.79 cm x 42.12 cm - with stand |
Weight | 4.24 kg |
Connectivity | |
Interfaces | DVI (HDCP) , VGA , HDMI |
Mechanical | |
Tilt Angle | -5/+25 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support |
Included Accessories | Stand |
Cables Included | 1 x VGA cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 20 kWh/1000h |
Power Consumption (Typical) | 22 Watt |
Power Consumption Stand by | 0.45 Watt |
Power Consumption Sleep | 0.35 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 56.7 cm - depth: 20.79 cm - height: 42.12 cm - weight: 4.24 kg , Without stand - width: 56.7 cm - depth: 6.07 cm - height: 33.59 cm - weight: 3.92 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
