Marketing description is not available.
Product Description | Acer K242HYL - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class F | Energy Consumption per Year | 31 kWh | Power Consumption (On mode) | 21.8 W | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 250 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Colour | Black | Dimensions (WxDxH) - with stand | 54 cm x 20.7 cm x 40.9 cm | Weight | 3.9 kg | Localisation | Czech Republic | Compliant Standards | MPR II | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Acer Adaptive Contrast Management (ACM) |
Colour | Black |
Dimensions (WxDxH) | 54 cm x 20.7 cm x 40.9 cm - with stand |
Weight | 3.9 kg |
Connectivity | |
Interfaces | DVI , VGA , HDMI , Audio line-out |
Mechanical | |
Tilt Angle | -5/+25 |
Miscellaneous | |
Cables Included | 1 x VGA cable |
Power | |
Power Consumption SDR (On mode) | 21.8 kWh/1000h |
Power Consumption (Typical) | 26 Watt |
Power Consumption Stand by | 0.35 Watt |
Power Consumption (Off Mode) | 0.35 Watt |
On / Off Switch | No |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years - carry-in |
