A rapid refresh rate and blazingly-fast response time deliver ultra-smooth motion scenes. Let the lower latency and immersive graphics of these monitors vastly improve your gaming experience.
Product Description | Acer Predator XB241YU - LED monitor - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class B | Energy Consumption per Year | 44 kWh | Power Consumption (On mode) | 30 W | Features | USB 3.0 hub | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | 2560 x 1440 | Brightness | 350 cd/m² | Colour Support | 16.7 million colours | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 54.1 cm x 25.9 cm x 53 cm | Weight | 6.6 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | MPR II |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Built-in Devices | USB 3.0 hub |
Panel Type | TN |
Backlight Technology | LED backlight |
Colour | Black |
Dimensions (WxDxH) | 54.1 cm x 25.9 cm x 53 cm - with stand |
Weight | 6.6 kg |
Audio | |
Type | Speakers |
Connectivity | |
Interfaces | DisplayPort , HDMI , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A) |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 30 |
Height Adjustment | 150 mm |
Miscellaneous | |
Cables Included | 1 x DisplayPort cable , 1 x SuperSpeed USB cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 27 Watt |
Power Consumption Stand by | 0.42 Watt |
Power Consumption (Off Mode) | 0.35 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54.1 cm - depth: 25.9 cm - height: 53 cm - weight: 6.6 kg , Without stand - width: 54.1 cm - depth: 6.35 cm - height: 37.85 cm |
Sustainability Information | |
ENERGY STAR Certified | Yes |
