Marketing description is not available.
Product Description | Acer S242HL - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class A | Energy Consumption per Year | 36 kWh | Power Consumption (On mode) | 25 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.276 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | Response Time | 1 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | MPR II, RoHS | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Panel Type | TN |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | HDCP, eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), Mercury free, Acer Empowering Technology, 6-bit gamma |
Colour | Black |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) , HDMI (HDCP) |
Mechanical | |
Tilt Angle | -5/+15 |
Miscellaneous | |
Features | Flicker-free technology |
Included Accessories | Stand |
Cables Included | 1 x VGA cable - VGA to VGA |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 26.1 Watt |
Power Consumption Sleep | 0.69 Watt |
Power Consumption (Off Mode) | 0.52 Watt |
On / Off Switch | No |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
