Essential series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
Product Description | Acer V196L - LED monitor - 19" | Device Type | LED-backlit LCD monitor - 19" | Energy Class | Class F | Power Consumption (On mode) | 17.5 W | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 at 75 Hz | Brightness | 250 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 5 ms | Input Connectors | DVI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Colour | Black | Dimensions (WxDxH) - with stand | 40.64 cm x 20.7 cm x 40.8 cm | Weight | 3.1 kg | Environmental Standards | TCO Certified Displays 8 | Compliant Standards | FCC Part 15, RoHS, WEEE, DDC-2B/CI, Directive 2009/125/EC, EN61000-3-3:2008, EMC 2004/108/EC, LVD 2006/95/EC, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, EN 55024:2010, EN 55022:2006+A1:2007 Class A |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 19" |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | HDCP, eColor Management, Acer Adaptive Contrast Management (ACM), Acer Empowering Technology, Transition Minimised Differential Signaling (TMDS) technology |
Colour | Black |
Dimensions (WxDxH) | 40.64 cm x 20.7 cm x 40.8 cm - with stand |
Weight | 3.1 kg |
Connectivity | |
Interfaces | VGA , DVI (HDCP) |
Mechanical | |
Tilt Angle | -5/+25 |
Miscellaneous | |
Cables Included | 1 x VGA cable |
Power | |
Power Consumption SDR (On mode) | 17.5 kWh/1000h |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 40.64 cm - depth: 5.2 cm - height: 33.7 cm - weight: 2.7 kg , With stand - width: 40.64 cm - depth: 20.7 cm - height: 40.8 cm - weight: 3.1 kg |
Sustainability Information | |
TCO Certified | TCO Certified Displays 8 |
