Everyday series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
Product Description | Acer V226HQL - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class F | Energy Consumption per Year | 32 kWh | Power Consumption (On mode) | 19 W | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Brightness | 250 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Colour Support | 16.7 million colours | Input Connectors | DVI, VGA | Voltage | AC 120/230 V | Colour | Black | Dimensions (WxDxH) | 50.8 cm x 20.68 cm x 39.04 cm | Weight | 3.66 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Acer EcoDisplay, Acer Adaptive Contrast Management (ACM) |
Colour | Black |
Weight | 3.66 kg |
Connectivity | |
Interfaces | VGA , DVI (HDCP) |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x VGA cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption SDR (On mode) | 19 kWh/1000h |
Power Consumption (Typical) | 19.5 Watt |
Power Consumption Stand by | 350 mW |
Power Consumption Sleep | 250 mW |
On / Off Switch | No |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - weight: 3.24 kg |
Sustainability Information | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
