Explore the angle that's perfect for you with this Professional Series monitor, which tilts, swivels, pivots and adjusts for height to achieve the optimal position for extended viewing. Its ergonomic design provides handsome style on your desk - or off: this monitor is wall mountable, giving you clear views with more room. The contrast ratio of the monitor is superior and the response is ultra-quick. In-Plane Switching (IPS) technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched. Moreover, the monitor allows you to connect to a wide variety of useful devices including notebooks, tablets and giant screen TVs, thanks to helpful VGA, DVI, HDMI, USB and even DisplayPort connectivity options. Professional Series monitors are mercury free. In addition, you'll see power savings of up to 68% thanks to advanced Acer EcoDisplay technologies and white LED backlighting, which cut your costs and conserve the earth's resources. Acer also uses recyclable packaging to further reduce ecological impact.
Product Description | Acer V226WLbmd - LED monitor - 22" | Device Type | LED-backlit LCD monitor - 22" | Panel Type | TN | Aspect Ratio | 16:10 | Native Resolution | 1680 x 1050 | Pixel Pitch | 0.282 mm | Brightness | 250 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Speakers | Internal | Voltage | AC 120/230 V | Colour | Black | Dimensions (WxDxH) | 50.58 cm x 20.7 cm x 41.91 cm | Weight | 3.52 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold | Compliant Standards | TUV GS, ISO 9241-307 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Panel Type | TN |
Vertical Refresh Rate | 75 Hz |
Horizontal Refresh Rate | 80 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | HDCP |
Colour | Black |
Weight | 3.52 kg |
Audio | |
Type | Speakers - stereo - internal |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V |
Power Consumption (Typical) | 17.2 Watt |
Power Consumption Stand by | 0.45 Watt |
Sustainability Information | |
TCO Certified | TCO Certified Displays 8 |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - carry-in |
