These are the world's first monitors that combine NVidia 3D Vision technology with Ultra HD resolution. This means you get no tearing, no stuttering - just buttery smoothness on more pixels for sharper game scenes. A rapid refresh rate and blazingly fast response time deliver ultra-smooth motion scenes. Ultra low motion blur technology makes moving objects appear perfectly sharp, with no visible blurring. Let the lower latency and immersive graphics of these monitors vastly improve your gaming experience.
These monitors help to reduce eye strain with Flicker-less, low-dimming, and anti-glare technologies. Flicker-less technology reduces screen flickering, which is a major cause of eye strain for people who look at monitors for long periods. Acer ComfyView technology cuts screen glare to further reduce eye strain. The Acer ErgoStand lets XB series monitors pivot, tilt, swivel, and move up or down, so you can find the most comfortable angle from where to oversee your push into enemy territory.
Product Description | Acer XB240Hbmjdpr - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class C | Energy Consumption per Year | 49 kWh | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 144 Hz | Pixel Pitch | 0.276 mm | Brightness | 350 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 1 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, MHL, DVI, DisplayPort, VGA | Speakers | Integrated | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V | Colour | Black | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Panel Type | TN |
Horizontal Viewing Angle | 176 |
Vertical Viewing Angle | 170 |
Backlight Technology | LED backlight |
Features | ErgoStand, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), matte, ComfyView, nVidia 3D Vision, Flicker-Less technology |
Colour | Black |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | DisplayPort , VGA , DVI , MHL / HDMI |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 120 |
Rotation Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x DisplayPort cable , 1 x DVI cable , 1 x VGA cable |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V |
Power Consumption (Typical) | 23 Watt |
Power Consumption Stand by | 500 mW |
Power Consumption Sleep | 450 mW |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
