This 24-inch display combines impressive performance with added features to make your workday more productive. Full HD resolution offers fantastic imagery and vibrant colors, whether you’re editing images or updating a website. High contrast ratios and quick 2ms response time ensure sharp, lag-free viewing for your most demanding applications. Built-in 2-watt speakers and a headphone jack mean you’ll never miss a word of your presentation or video call. And VGA, DVI-D and DisplayPort connectors make it easy to hook up your computer and external devices. While you focus on business, the ergonomic stand lets you work comfortably – adjust the height, swivel and tilt to the ideal position, or pivot the screen from landscape to portrait mode.
Product Description | AOC Professional E2460PQ - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.276 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 50000000:1 (dynamic) | Response Time | 2 ms (gray-to-gray) | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 56.54 cm x 24.35 cm x 39.36 cm | Weight | 6.38 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | TUV GS, RoHS, ISO 9241-307, EuP | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Panel Type | TN |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Video Bandwidth | 165 MHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
Features | HDCP, Eco-Mode, e-Saver technology |
Colour | Black |
Dimensions (WxDxH) | 56.54 cm x 24.35 cm x 39.36 cm - with stand |
Weight | 6.38 kg |
Audio | |
Type | Speakers |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) , DisplayPort |
Mechanical | |
Tilt Angle | -5/+22 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x audio cable |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 22 Watt |
Power Consumption Stand by | 0.5 Watt |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
