Experience a new level of sharpness with this large 68.5 cm (27") monitor. The Q2778VQE utilizes a state-of-the-art TN panel with the stunning WQHD resolution of 2560 x 1440 pixels. With its D-Sub, DVI-D, HDMI and DisplayPort connectors, this energy-efficient display offers you a multitude of applications, delivering exceptionally crisp and vivid images for even the highest demands. Benefit further from flexibility tilt and swivel function. The Q2778VQE comes in a glossy black design and features eco-friendly LED-backlights. Let the Q2778VQE impress you today!
Product Description | AOC Q2778VQE - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class C | Energy Consumption per Year | 67 kWh | Power Consumption (On mode) | 46 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.2331 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 80000000:1 (dynamic) | Response Time | 1 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI, DisplayPort, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black, silver | Dimensions (WxDxH) - with stand | 64.03 cm x 29.91 cm x 47.07 cm | Weight | 4.72 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | RoHS, Lead-Free, REACH, TUV Bauart, EAC, ISO 9241-307 Class 1, Mercury-free | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | TN |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
Controls & Adjustments | Volume, brightness, contrast, H/V position, sharpness, gamma correction, input select, graphic / text mode, phase, clock, luminance |
OSD Languages | Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean |
Features | HDCP |
Dimensions (WxDxH) | 64.03 cm x 29.91 cm x 47.07 cm - with stand |
Weight | 4.72 kg |
Connectivity | |
Interfaces | DVI , HDMI , VGA (HD-15) , DisplayPort |
Mechanical | |
Tilt Angle | -4/+21 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x VGA cable - 1.2 m , 1 x DVI cable - 1.5 m , 1 x DisplayPort cable - 1.5 m |
MTBF | 50,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 45 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
On / Off Switch | No |
Dimensions & Weight (Shipping) | |
Shipping Width | 72.9 cm |
Shipping Depth | 21.5 cm |
Shipping Height | 55.5 cm |
Shipping Weight | 6.77 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 6.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
