The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can be activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness.
Product Description | ASUS VK248H - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class A | Energy Consumption per Year | 29 kWh | Power Consumption (On mode) | 20 W | Features | Stereo speakers, 1.0 megapixel camera | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.2768 mm | Brightness | 250 cd/m² | Contrast Ratio | 50000000:1 (dynamic) | Colour Support | 16.7 million colours | Speakers | Integrated | Display Position Adjustments | Tilt | Colour | Black | Dimensions (WxDxH) - with stand | 56.8 cm x 6.2 cm x 35.9 cm | Weight | 5 kg | Microsoft Certification | Compatible with Windows 7 | Compliant Standards | UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, GOST-R | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Built-in Devices | Stereo speakers, 1.0 megapixel camera |
Vertical Refresh Rate | 76 Hz |
Horizontal Refresh Rate | 83 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Controls & Adjustments | Volume, brightness, input select, colour temperature, aspect control |
Features | Cable management cover, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale |
Colour | Black |
Dimensions (WxDxH) | 56.8 cm x 6.2 cm x 35.9 cm - with stand |
Weight | 5 kg |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI-D , HDMI , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | 25 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), wall mountable |
Cables Included | 1 x VGA cable , 1 x DVI cable , 1 x audio cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Power Consumption (Typical) | 42 Watt |
Power Consumption Stand by / Sleep | 0.5 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - LCD panel - 3 years |
