ASUS Designo MX27UQ feels right at home in any living space, with a space-saving ultra-slim profile and an exquisite edge-to-edge frameless panel. With a high pixel density, it gives you sharper images with more details and textures. Having a higher pixel count also means more efficient multitasking. Whether you're watching 4K Ultra HD video streams online, or re-watching your own video clips, the Designo MX27UQ lets you fully enjoy them in all their glory.
Product Description | ASUS MX27UQ - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class B | Energy Consumption per Year | 47 kWh | Power Consumption (On mode) | 32 W | Panel Type | AH-IPS | Aspect Ratio | 16:9 | Native Resolution | 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 30 Hz, HDMI2: 60 Hz) | Pixel Pitch | 0.155 mm | Brightness | 300 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Colour Gamut | 100% sRGB | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black, icicle gold | Dimensions (WxDxH) - with stand | 61.44 cm x 22.54 cm x 42.95 cm | Weight | 5.5 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, RCM, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Vertical Refresh Rate | 40 - 76 Hz |
Horizontal Refresh Rate | 29 - 94 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Controls & Adjustments | Input select, colour temperature |
Features | HDCP, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology |
Dimensions (WxDxH) | 61.44 cm x 22.54 cm x 42.95 cm - with stand |
Weight | 5.5 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 3 Watt |
Connectivity | |
Interfaces | DisplayPort , 2 x HDMI , Headphones , USB |
Mechanical | |
Tilt Angle | -5/+20 |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), ASUS SonicMaster, Stereo Bluetooth Wireless Technology, Bang & Olufsen ICEpower, frameless, Asus AudioWizard |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable , 1 x power cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 52 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
On / Off Switch | No |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - LCD panel - 3 years |
