Asus PA328Q 31.5" Wide IPS LED Monitor 4K
Key features
  • Professional-grade 32-inch 4K/UHD display with four times the pixel density of Full HD displays
  • Factory pre-calibrated, industry-leading color accuracy with 100% sRGB and Rec. 709 color space support
  • Extensive connectivity with HDMI 2.0/1.4, DisplayPort 1.2, and MHL 3.0 for smooth 4K/UHD content playback
  • ASUS Eye Care Technology which eliminates onscreen flicker
  • Adjust for maximum comfort with ergonomic tilt, swivel, pivot and height adjustments plus wall-mount capability
Product codes
chevron icon
chevron icon
Open your eyes to breathtaking levels of detail with the ASUS PA328Q true 4K ultra-high definition monitor. It features a super-narrow bezel design and a 16:9 aspect, 32-inch panel to give you stunning visuals in resolutions of up to 3840 x 2160. PA328Q gives you 300% more onscreen space to work with than similarly-sized Full HD displays, allowing you to spread out your various work windows for more productive multitasking. Revel in pure, expressive hues thanks to accurate, true-to-life color reproduction. Each PA328Q monitor is factory pre-calibrated to guarantee industry-leading color accuracy, so your images are accurately reproduced onscreen, allowing you to see exactly how your work is going to look when it's finished. Increase productivity and work smarter with ASUS QuickFit Virtual Scale. PA328Q provides you with an onscreen grid overlay so you can align and preview photos and documents in their actual sizes prior to printing. There's also an intuitive 5-way navigation joystick so you can easily access and switch OSD settings on the onscreen menu. When you're spending countless hours working on a project, it's important to have a display with low blue light technology to reduce instances of strained eyes. Say goodbye to tired eyes with ASUS Eye Care technology.
chevron icon
Product Description ASUS PA328Q - LED monitor - 32"
Device Type LED-backlit LCD monitor - 32"
Energy Class Class B
Energy Consumption per Year 67 kWh
Power Consumption (On mode) 46 W
Features 5-way navigation button
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1, HDMI3, MHL: 30 Hz, HDMI2: 60 Hz)
Brightness 350 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 6 ms (grey-to-grey)
Colour Support 1.074 billion colours (10-bit)
Colour Gamut 100% sRGB
Input Connectors 2xHDMI, DisplayPort, Mini DisplayPort, MHL
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) - with stand 73.44 cm x 24 cm x 61.5 cm
Weight 11.68 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, FCC, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, UkrSEPRO, KC, TUV Rheinland Flicker Free Certification
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
