The Swift PG348Q expands your scope, allowing faster target acquisition while increasing immersive visuals with a 34-inch curved ultra-wide IPS panel. Bristling with advanced display tech, the Swift PG348Q also features NVIDIA G-SYNC technology for smooth and seamless gameplay, while simultaneously sporting a great refresh rate, eliminating roadblocks between your skill and victory. Add the armored design and amazing ASUS features and you're looking at a monitor that is truly unrivaled.
Product Description | ASUS ROG SWIFT PG348Q - LED monitor - curved - 34" | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class B | Energy Consumption per Year | 77 kWh | Power Consumption (On mode) | 53 W | Curved Screen | Yes | Adaptive-Sync Technology | NVIDIA G-SYNC | Features | 5-way joystick, USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 21:9 | Native Resolution | 3440 x 1440 at 100 Hz | Pixel Pitch | 0.2325 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (grey-to-grey) | Gaming | Yes | Colour Support | 1.074 billion colours (10-bit) | Colour Gamut | 100% sRGB | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Armor titanium, plasma cooper | Dimensions (WxDxH) - with stand | 82.9 cm x 29.7 cm x 55.8 cm | Weight | 11.2 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, RCM, CEL level 2, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 34" |
Curved Screen | Yes (3800R) |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Pixel Per Inch | 109 |
Vertical Refresh Rate | 24 - 100 Hz |
Horizontal Refresh Rate | 30 - 140 kHz |
Gaming | Yes |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Controls & Adjustments | Colour temperature |
Features | HDCP, frameless, Skin-Tone Selection, Trace Free Technology, ASUS Splendid Video Preset Mode, ASUS GamePlus, Low Blue Light Mode, Flicker Free technology, ASUS Smart Air Vent Design, ASUS GameVisual Technology, Turbo key, Colour Temperature Selection |
Dimensions (WxDxH) | 82.9 cm x 29.7 cm x 55.8 cm - with stand |
Weight | 11.2 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Input | |
Type | 5-way joystick |
Connectivity | |
Interfaces | DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , HDMI , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 100 |
Height Adjustment | 115 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DisplayPort cable , 1 x USB cable , 1 x HDMI cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 100 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 82.9 cm - depth: 10.9 cm - height: 37.3 cm , With stand - width: 82.9 cm - depth: 29.7 cm - height: 55.8 cm - weight: 11.2 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 32 cm |
Shipping Depth | 94.2 cm |
Shipping Height | 50.8 cm |
Shipping Weight | 15.5 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
